Motherboard for a i9 9900k, 64GB 3000mhz Ram + RTX3070
Solved by Hairless Monkey Boy,
21 minutes ago, Lundgreen said:Would the: Asus TUF Z390M-Pro Gaming, be compatible?
Yup.
21 minutes ago, Lundgreen said:And would I need to be sure which BIOS it's updated for?
Z390 launched with the 9900K. So even the initial BIOS should be compatible.
Edit:
That said, it's still probably best to sell the 9900K as new in box. You can get a good price for it. Then you can buy a CPU that's compatible with your existing board that is both better and cheaper than the 9900K, and pocket the difference. Like a 5600X.
