Need help for my build.
Go to solution Solved by Fl0yd-,
to answer the actual questions,
- 850w is more than enough, you will get over-satisfying numerous cables in the box including single cables that has both 8 pins (use them myself)
- you should go with corsair for better compatibility.
I have the rm1000x if you have any questions, since they're in the same family.
Budget (including currency): 2400 euro
Country: Belgium
Games, programs or workloads that it will be used for: forza 5, rocket league
GPU. gaming z trio 3080
CPU. ryzen 9 5900
motherboard. Asus rog strix B550.A
Cpu cooler. Corsair h100i elite cappelix
SSD. samsung 980 pro 1TB
Case. Lian Li O11 dynamic
Ram. 32gb corsair vengeance rgb pro SL DDR4 3600
Monitors. Using a 27inch right now but I will be getting a 34 inch aswell
Hi everyone, im building my first pc and I have some questions,
My questions are that im getting a corsair rm850x PSU and I dont know if that is enough power for my setup, and the card also needs 2x 8pin so I dont know if there will be enough 8 pins.. some people say yes, and some say no so I came here for help.
My second question is if my motherboard has 2 rgb headers because I want some lian li SL120 fans and some corsair QL120 fans but then I will have 2 hubs, one for Lian Li and 1 corsair hub which im not sure if my motherboard has..?
Or should I just go all corsair..?
https://linustechtips.com/topic/1445119-need-help-for-my-build/
For ease of use, sticking to one brand of RGB is better. There still isn't a standardized RGB application, so every company has its own proprietary software.
https://linustechtips.com/topic/1445119-need-help-for-my-build/#findComment-15493380
budget wise, you're fine going for a crucial p2 500gb ssd and a seagate 2tb hdd to cut down on the price. rocket league can practically run on a toaster and forza would only differ in loading times unless you're desperate to load in as quick as you can.
PERIPHERY
- Table : IKEA Karbly 8FT counter top (brown) w/ 2 ALEX black drawers & OLOV LEG
- Chair : Herman Miller Aeron Remastered Ergonomic Chair
- Mouse 1 : Logitech Superlight X 2 (Black) (Using Now)
- Mouse 2 : Razer Viper V2 Pro (Black)
- Keyboard 1 : Logitech G413 SE Brown switches Lubed
- Keyboard 2 : Ducky One 2 SF Black CherryMX Silver Switches
- Monitor 1 : Benq Zowie XL2566K 360HZ 0.5MS
- Monitor 2 : ASUS PG279QE 1440p 165HZ
- Mousepad 1 : The Glorious 3XL Extended Mousepad (Black)
- Mousepad 2 : Benq G-Sr Speed Mousepad (Black)
- Mouse-Bungee : Razer Bungee V2 (only when wired)
- Headset : Beyerdynamic DT990 PRO 250 OHM grey/black
- Microphone : Shure MV7 XLR
- Mixer : TC-Helicon GOXLR
- Camera : Nikon 250D W/ Elgato CAMLINK 4K
- WebCam 1 : Logitech Brio 4K
- Webcam 2 : Logitech C922 1080p
- Controller : PS5 Controller Whiteout Edition
PC
- CPU : Intel I7 12700KF
- CPU-Cooler : NZXT Kraken X62
- GPU : Zotac Gaming GeForce RTX 3070 Ti Trinity OC 8G
- Motherboard : MSI MAG Z690 WIFI
- RAM : Corsair Vengeance Pro RGB 64GB
- Case : NZXT H700I Black/Red matte
- HDD : 2x 6TB (12TB) Seagate Exos 7E10 12GB/s
- SSD : 1TB Crucial P1 NVME M.2
- PSU : Corsair RM1000X (1000W Plus Gold) (W/ Red Sleeved Premium Corsair Cable kit)
https://linustechtips.com/topic/1445119-need-help-for-my-build/#findComment-15493417
PERIPHERY
PC
https://linustechtips.com/topic/1445119-need-help-for-my-build/#findComment-15493420
