Hi, Im pretty new to Pc gaming. I had a pc that was built from a family member but I was wondering what should I upgrade first. My storage is no issue since I have plenty of space.
My pc specs were:
Intel core i5 4570
Nvidia 1050 ti Motherboard
Lenovo Sharkbay Ram
Ramaxel Technoledgy DDR3
Antex 900 Case
Thanks,
https://linustechtips.com/topic/1444419-what-do-i-upgrade-first/
Depends on what you want from the PC. To browse web, watch movies and some light games, don't bother with anything - it's already pretty much at max for this. If you want to game a bit more regularly on it though, better get an entire new system. This is already a very old platform and it's not worth pouring money in it, unless you plan to play only old games on it.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
Pretty much just the GPU. Some used $250~ will go a long way from a 1050ti, something like a 2060S, Vega 64 or 5700XT
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
I was mainly going to be playing games that would run on a ps4. Stuff like Nier automata. I think I'll take "venomtail" suggestion and upgrade the gpu first though
yup, I would aslo probably recommend buying an i7-4770 as well for cpu upgrade, this will likely be a huge help in cpu bound games
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
I wouldn't be spending money on an RTX card though. Most probably GTX 1080 (Ti) will be perfectly sufficient for everything and will save you quite a lot money.
I reccomend that you upgrade your ram. 16 GB are perfect and ddr3 are now way cheaper. About the GPU, you might need to get a better PSU, for more power. As @GorujoCY mentioned, an i7-4770 will be great.
But if you think about it, it might be better to get a new build.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” - Albert Einstein
Power supply so you can run better stuff
2.
Case if you want to have a good time upgrading. $90-150 for some nice good airflow and good to work in
3. Graphics card. 1080 are as low as 200 on eBay from what I saw.
4. Cpu/mobo/ram
I wouldn't get "more" ddr3 at this point. I'd just get a new "core" configuration if you need more memory/cpu power.
Power supply is something I thought I did well upgrading, but it's not quite as high as I needed in the past.
Case is a dream. Amy time I open it, it's pure joy that it's going to be easy to do things.
1050 is "slow" but it's still plenty good. If you want more frames in games, get a 1080 or something else. Some 3060 are as low as 380~ new. Rtx is awesome.
