I just wanted to know if you guys could help me with my pc. My cpu gets up to a temperature that I would rather not hit 85c+ With fans almost at full speed. Any tips or fixes I could do would be much appreciated.
Specs
Mobo: msi z590
Cpu: intel i9 10900k
Gpu: rtx 3070
Cpu cooler: nzxt kraken z73 360mm
Ram: Corsair vengeance 32gb
Fans: 6 Lian li SL fans daisy chained in groups of 3
Case: lian li o11 razor edition
One set of 3 fans is bringing air into the case from the bottom and the other set is pushing air through the aio out the top of the case
https://linustechtips.com/topic/1444342-my-cpu-temp-is-high/
85C is pushing it a bit but within limits. Most are okay to 93-95C. Your fan configuration should be fine, as heat rises. One or two to the rear couldn't hurt if the case allows it.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1444342-my-cpu-temp-is-high/#findComment-15488289
You don’t think that it’s to high for almost maxed out fan speed? I’m trying to get around 75c average
https://linustechtips.com/topic/1444342-my-cpu-temp-is-high/#findComment-15488303
If you're concerned about CPU temp, that one is rated for 100C at the die. Lower is better, but 85C is hardly a problem, unless you're seeing that at idle.
ADDED: Fan / fan speed is only part of the  equation -- case airflow is a factor also.
Revised, more info
https://linustechtips.com/topic/1444342-my-cpu-temp-is-high/#findComment-15488307
Well if you are really that concerned about temps and fan noise you could always undervolt to try and reduce the heat. I know sometimes motherboards provide way more voltage than is needed just to be conservative. Obviously some cpus will need that voltage but not all and it really depends on the silicon lottery. That is probably where I would start
https://linustechtips.com/topic/1444342-my-cpu-temp-is-high/#findComment-15488318
