10 minutes ago, ARKHAM66 said:
Hi I have had this issue for a couple days now and tried to fix it does anyone know how to as it has become very annoying
Don't triple post. Could  you post your specs please?
WHEA_UNCORRECTABLE_ERROR is a somewhat generic error for a hardware issue.
First time I had this error a few weeks ago was due to bad RAM. I ran the Windows Memory Diagnostic tool and it detected problems. I also ran a memtest86 and after failing it I got the memory replaced, which fixed it.
Second time I got this error it was because of bad configuration in BIOS. I was tinkering with the settings there and changed something that caused BSODs with this error. Resetting the BIOS to default helped.
Ryzen 7 5800X w/ DeepCool AK620 | ROG Strix B550-A | MSI 3070 GAMING Z TRIO | G.Skill Trident Z Neo 2x8GB 3600C16 | Corsair RM750x | Corsair 5000D Airflow w/ 3x Corsair QL120 RGB
I was going to say that a WHEA could be almost anything. Why I asked for his specs.  Talking of specs,  how does the AK620 cope with that 5800X?
Hitting 90C within seconds on multithreaded Cinebench R23. Playing Cyberpunk it's around 75-80ish. DeepCool support say 90C is normal for a 5800X on multithreaded R23 though it seems pretty high to me considering Gamers Nexus had a pretty positive video about the cooler.
Long story short so I don't derail the thread too much, the retention bracket screw broke off when remounting and I'm thinking it may have had a defect from the start. Thermal paste layer looked thick and not spread out well as if pressure isn't being applied properly. I'll find out when the new brackets arrive.
Corsair Vengeance RGB Pro 32GB
Western Digital Black SN770 NVMe Gen4 M.2 SSD Corsair iCUE H150i Elite Capellix 360mm ARGB AIO Cooler
Corsair RM850 Gold Modular 850W Power Supply V2
ASUS GeForce RTX 3070 Ti TUF Gaming OC 8GB
ASUS TUF Gaming Z690-PLUS Wi-Fi D4 Motherboard
Intel Core i9 12900KF Processor
Western Digital Blue 2.5in SATA SSD 2TB
