Give speakers more power through USB
So those are passive speakers.
The reason it is very quiet is because the analog signal being output by your devices' headphone jacks have been amplified to a comfortable signal designed for headphones and active speakers.
A USB cable won't work because it will send digital information. It still needs to be converted into analog - thus you need a DAC (digital to analog converter).
If you want to transfer audio from a PC to passive speakers you'll need to buy a minimum of 1 item.
Thankfully all PC's have a built-in soundcard that does the digital conversion already, so an external DAC is not necessary.
The analog signal being output by the PC still needs to be fed to a speaker amplifier - preferably one with a volume control - if you want to actually hear the content.
