Subwoofer for my bookshelf speakers
znb1
I’m looking for a decent subwoofer to pair with my pioneer dm40bt bookshelf speakers. Not looking to spend much more than 150gbp (180usd). Any recommendations?
Looking at Amazon there are many options from respectable brands in that price range.  Given that you aren't in the same part of the world as me I'm uncertain how to recommend something.  I would suggest shopping by brand, it looks like monoprice, polk audio, yamaha and jamo have offerings, I saw dayton audio as well, can't remember their reputation.  In that price range you would be looking for something that is going to do what it claims to do and won't break easily so avoid knockoffs.
Also I googled your speakers and they have no real output, only one to power the other speaker, so I am unaware of how that would affect a subwoofer running off one channel.  I know that subwoofers are mono but I can't promise that something with speaker bindings will work with just one channel.  Also I would imagine bass tracks aren't always the same from Left to Right.  So I would do a little sleuthing to find out how this might affect you.
Oh, I just realized..... if you are using a cable to connect ignore that last bit, I was assuming you used a BT connection.  You could probably use a 3.5mm to RCA connection from your soundcard.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
In the US you're probably looking at a Dayton sub...
Dayton Audio SUB-1000
Other considerations are on here -
If you're able to - go used. Something like a PB-1000 or SB-1000 is pretty awesome.
3900x | 32GB RAM | RTX 2080
1.5TB Optane P4800X | 2TB Micron 1100 SSD | 16TB NAS w/ 10Gbe
QN90A | Polk R200, ELAC OW4.2, PB12-NSD, SB1000, HD800
