I do most of my gaming and productivity on an Alienware r17, but I've got some money lying around and want to build a Linux Machine because there's a good few things I do that require Linux, and I'm a pretty competent maker so I plan on making a custom case and doing a mini itx build.
What direction should I go in for CPU? I know for compiling and the like I'm after multi-threaded performance, but what's the best route? I plan to spend around 300-400$ on the components, and wondering what route I should take; something like a 12th gen i3, or an older used i7? I plan to spend around 300-400$ on the components not counting custom materials for the case. Picking a CPU is the part I am least confident on. I want the best performance I can get of course, but to be fair a lot of this build is just for fun 😄 NOT a gaming machine, might use it for media but don't need to crank out those high single core clocks or blazing FPSs.
any help appreciated!!
Budget (including currency): 300-400 USD
Country: USA
Games, programs or workloads that it will be used for: just a Linux Machine, maybe some media
Other details building a custom case! Plan to use a modular power supply just to make that easier but might not if it hurts my budget too much.
https://linustechtips.com/topic/1441353-type-of-cpu-for-linux-machine/
Budget: AMD Ryzen 7 1700 (used, Aliexpress)
Mid-range: AMD R7 3700/5700 (new or used)
High performance: AMD Threadripper
Hard-core: AMD EPYC 3151 SoC (server-grade stuff, usually integrated on a mainboard already, Asrock Rack and Gigabyte have suitable boards)
Alternatives include R5 4600G and R7 4750G (both APU's) if you don't (want to) spend money on a GPU.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
"Linux machine" is a very broad term. That could be anything from a Ryzen 9 5900X spending its life doing crazy shit with Arch right on down to Puppy Linux on a Pentium II.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
You can squeak in around there with an i3 1200 and the lowest tier SFX PSU Silverstone has (I assume you'd want an SFX PSU if the point is to be SFF) and already have a drive to use for boot:
PCPartPicker Part List: https://pcpartpicker.com/list/DFhbwc
CPU: Intel Core i3-12100 3.3 GHz Quad-Core Processor  ($129.98 @ B&H)
Motherboard: Gigabyte Z690I AORUS ULTRA LITE DDR4 (rev. 1.0) Mini ITX LGA1700 Motherboard  ($150.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($46.99 @ Amazon)
Power Supply: Silverstone SX300-B 300 W 80+ Bronze Certified SFX Power Supply  ($67.78 @ Amazon)
Total: $395.74
Generated by PCPartPicker 2022-07-05 17:52 EDT-0400
If you don't have a drive you can get a cheap ADATA or SK Hynix SSD for ~$30, they're usually fine for linux box tinkering unless you have a need for more space.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
