$4000 Extreme Build
23 minutes ago, BobTheBuilder99 said:Yeah honestly I'm not sure where that build came from. Thanks for your tips they have been helpful. Do you have any other concerns about my build that I should be aware of? I really appreciate just another person taking a good look at it for me.
This is pretty much the same performance for a lot less money. Only main difference is the cpu. So you just lose the extra e cores and of course the cpu is locked (You can still unlock power limits). For gaming there wouldn't be any difference at 4K and it would be pretty even at 1440p.
So the other thing to look at would be whether the extra 4 e cores make a difference for Graphics design. Websites like Puget systems are a good source of info for suggested hardware assuming the software being used is there.
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor ($312.96 @ Newegg)
CPU Cooler: Scythe Fuma 2 Rev.B 39.44 CFM CPU Cooler ($65.98 @ Amazon)
Motherboard: MSI MAG B660 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard ($189.99 @ Amazon)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($109.99 @ Newegg)
Storage: Western Digital Black SN850 2 TB M.2-2280 NVME Solid State Drive ($239.99 @ Amazon)
Video Card: MSI GeForce RTX 3080 Ti 12 GB VENTUS 3X OC Video Card ($999.99 @ Amazon)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: Corsair HX1200 Platinum 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply ($224.99 @ Amazon)
Total: $2253.88
Generated by PCPartPicker 2022-07-02 13:16 EDT-0400
