Pc shuts down then reboots at low resolution
Solved by Mayday793,
You can try DDU, its a much better uninstaller than the windows uninstaller, because the windows one can miss some things in the registry.
Another alternative is clicking this link:https://disq.us/url?url=https%3A%2F%2Fcdn.discordapp.com%2Fattachments%2F850202668315181136%2F988956958193233920%2Fnvidia-error43-fixer_113.zip%3An8Z8w5T-SSbi_osVjF1VTpuQE38&cuid=2989934
Which will automatically download a zip file to you (i just downloaded it to check it was safe ). Unzip it and Run the "nvidia-error43-fixer.bat" file as an administrator. That should be your first thing to try.
