i have a ryzen 9 5950x cooled by a cooler master 360mm AIO. the chip reaches 90 degrees celsius which is the max temp limit of the chip as of when i checked in ryzen master. i have removed the plastic cover from under the cold plate and have applied thermal paste multiple times. there is still no difference. the ambient temp is 36 degrees celsius. is there any thing else i can do ?
https://linustechtips.com/topic/1438950-cpu-temps-during-cinebench/
What AIO you got? Have you checked the bracket for the Cooler is tight? (the one mounted on the motherboard). If your AIO is old, the design for the cold plate might be optimized for older CPUs.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Nothing you can do. Don’t bench hard with high ambients, get a portable ac unit. 35c ambient is hot as fuck.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
thats actually a good day where i live.
3 minutes ago, DoctorNick said:
What AIO you got?
cooler master ML360L
as tight as i could turn it.
theyre selling the same AIO for 12th Gen too. so im assuming that its not that old
Overlooked that you got 36c ambient. Thats pretty hot. You could get a better cooler. Maybe consider getting something like the Liquid freezer II 360. Overall better and more silent, performs very good:
Gaming PC:
Linux PC:
It’s 20c out right now, a beautiful morning.. but that will change later as the temp is supposed to climb to 31 feels like 37. It’s going to be hot as balls at work, I’m there now and it already is ugh. At my apartment my old computer lived in the 30s all summer.. it ran fine it just got extra warm 😄
if its ok to ask what region of the world are you living to get ambients of 37? just curios.
1 hour ago, JKRsega said:
My ambient is 37 - 44.  How can I change that?
Move or get AC 😁
Canada 🇨🇦
7 minutes ago, JKRsega said:
With your 3000rpm fans... Showoff lmao🤣
I normally cap them at 2K because I like my quiet time as I get older 😄
15 minutes ago, JKRsega said:
I'm 41 bud, not just you whose an old fart...🤪
I’m 44 or 45 😄
