i plugged my front fans into the aio hub and the rgb isn't working
madfad
i plugged my front fans into the aio hub and the rgb isn't working can someone please help?
you need to give way more information than you did.
Like.... *any* information.  What are you working with?
Look around at the Pins in your motherboard, is there a Pin which says ARGB?
