Two external HDDs show difference of 200GB usage with the same data?
Solved by Kilrah,
Are they formatted differently, e.g. one NTFS and one ExFAT? Also even with the same filesystem you can choose different cluster sizes, and if your content consists of many small files a drive formatted with large clusters will have way more overhead loss.
You can use TreeSize Free as admin to scan both drives and compare to see if there are files on one you're missing.
Featured Topics
Marie Rose ·
Posted in Power Supplies5 -
4
3
3
10
10
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning23 -
5
6
