NZXT H1 V2 3080 Build
Solved by Origami Cactus,
If the focus is heavily vr and gaming, especially for the money you are paying for the motherboard and ram, you could get the faster and much more power efficient 5800x3D and an Asus Strix b550-i. It has less usb ports, but it is one of the only itx motherboards with the front panel type-C connectors needed for the H1 case. You could pair that CPU with any old DDR4 3600mhz CL16, and it would be better for vr.
Then use the extra saved money to get the 12GB variant of RTX 3080.
The SSD's are fine, can't really go wrong with Samsung.
