Unreal Engine Games Crashing
Go to solution Solved by FaTaLMercenery,
After some more looking around online, I found other people with similar problems and a whole thread of people saying the recent Nvidia drivers are just complete trash. I reverted back to driver 472.12 and now stability seems to be just fine in all the games I have played. Needless to say, I will be staying at that version for a while.
Gonna put this here in case anyone else has a similar issue and maybe this can help them as well.
I recently upgraded my pc (100% new except PSU and storage, specs at the bottom). It's not a fresh install of Windows 10, but I did run DDU on my old computer to remove all the drivers before moving the storage to my new computer. Since then, every time I try to play games made with Unreal Engine they crash after anywhere from 2 minutes to an hour. My list of games that I've played since upgrading isn't extensive: Satisfactory, Fortnite, and Oxygen Not Included(ONI). The first two are made in Unreal Engine 4 and 5 respectively while ONI is a Unity game.
Fortnite crashed twice(I only attempted to play twice) and Satisfactory, as of writing this, has crashed six times. I played ONI for about 3 hours on a few occasions and there were no issues. Every time I get a crash report it starts with the following: "Unhandled Exception: EXCEPTION_ACCESS_VIOLATION reading address 0xffffffffffffffff". The memory address seems to always be different, that's just the most recent one I have received.
My GPU driver version is 512.95 - Released 5/24/2022
I built the computer around 5/14/2022
Specs:
CPU - AMD Ryzen 5 5600X
MBD - ASRock B550 Taichi (Razer Edition)
RAM - Corsair Vengeance DDR4 32GB (2x16GB) 3600MHz C16
GPU - EVGA FTW 3080 LHR
PSU - Corsair RM850x
I'd like to resolve this issue since the games that are crashing are the main games I want to play.
Update:
I ran the memory diagnostics tool and it says 'detected no errors'. I also ran 'sfc /scannow' in command prompt and it came back with "Windows Resource Protection did not find any integrity violations." although occasionally when I have issues with my computer and run this, is does find issues and "fixes" them.
https://linustechtips.com/topic/1436579-unreal-engine-games-crashing/
was it a fresh install of Windows?  If not, a reinstall might fix it.  Could also be a memory error.  Run the windows memory diag tool at next boot.  if that shows nothing run memtest x86 (you'll need a small pen drive for that one but both are free)
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
It's not a fresh install of windows, but I did run DDU on my old computer to remove all the drivers before moving the storage to my new computer. I would like to avoid having to do a fresh install, but I will if it's necessary.
I just ran the memory diagnostics tool and it says 'detected no errors'. I did also run 'sfc /scannow' in command prompt and it came back with "Windows Resource Protection did not find any integrity violations." although occasionally when I have issues with my computer and run this, is does find issues and "fixes" them.
Add all this to OP.
