Use a linen cloth and a cleaning alcohol preferably 75% or higher.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917139
You can just use rubbing alcohol and toilet paper. Just make sure that you don't have any fibers left over on the CPU/cooler when you're done.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917141
99% isopropyl alcohol and tissue paper.
After removing, clean with a Lint-free cloth
I think i just quoted linus
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917147
You will need some kind of solvent (like rubbing alcohol, or even nail varnish remover!) to clean the old paste off and a microfiber cloth so that no residue (from tissues etc) is left behind
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917162
i bought some specific cleaner for like 5 bucks. works perfect, i have no ragreds.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917190
Why do I need a solvent?
The alcohol makes removing the paste much easier, and leaves the surface cleaner.
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917205
Do I have to use alcohol then?
You can use perfume. Just kidding, why can't you get alcohol.
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917271
Just don't have it at hand right now, and I am borrowing some thermal paste from a friend.
White spirit? Nail polish remover might work.
https://linustechtips.com/topic/143593-cleaning-thermal-paste/#findComment-1917294
