So I am choosing a case for my next build, what should I do?
Case Options (Both Black Color):
Corsair 4000D Airflow
Lian Li O11 Dynamic Mini
Lian Li O11 Dynamic (Normal Size)
Specs:
Ryzen 9 5900X
Gigabyte Aorus B550 Elite AX V2
NZXT AIO
32GB RAM
EVGA RTX 3070 Ti
https://linustechtips.com/topic/1434078-which-case/
Case is 100% personal preference, chose the one that you like most
My personal preference is screw cases and shove the computer ontop a cardboard box 🙂
also arctic liquid freezer demolish nzxt aios so if you care about performance thats the best aio on the market
https://linustechtips.com/topic/1434078-which-case/#findComment-15415935
4000D would be the budget option. It's a fine case. O11D Mini is nice although there is a couple of things that you need to know if you get it. 1. If your using an ATX motherboard (which you are), it is not possible to install a 360mm radiator. You can install it in the bottom but I couldn't possibility recommend that. 2. The O11D Mini only supports SFX power supplies. Those can get quite pricey fast. Apart from that, it's basically the same as the regular O11D.
As another person said, you should mainly pick a case based on which one you like the best. Just make sure that it has good airflow and can fit all your parts inside it.
Due to my inability to think before I type, I frequently edit my posts. Please refresh before responding!
Tag me @drdrewnatic or quote me so I can see your response.
______________________________________________________________________________________________________________
CPU: INTEL CORE I5-12600K GPU: ASUS ROG STRIX GEFORCE RTX 2070 OC MB: GIGABYTE B660 AORUS MASTER DDR4 RAM: 2X8GB G.SKILL TRIDENT Z RGB 3200 CL16 BOOT: CRUCIAL P5 PLUS 1TB SSD: SAMSUNG 860 EVO 500GB HDD: SEAGATE 2TB 7200RPM PSU: EVGA G3 650W COOLER: THERMALRIGHT PEERLESS ASSASSIN 120 SE ARGO
01101100 01110100 01110100 01110011 01110100 01101111 01110010 01100101 00101110 01100011 01101111 01101101
https://linustechtips.com/topic/1434078-which-case/#findComment-15415949
4000D is nice & minimalistic, looks pretty normal.
O11 Mini is good, I can put a 280 on the side. I am okay with using a SFX PSU, I can find a 850W SFX PSU which will be pricey but doable.
O11 Dynamic is very nice, I can put a 360 on the top and it's big.
https://linustechtips.com/topic/1434078-which-case/#findComment-15415994
6 minutes ago, Rob_dog said:
I'm not going to use that GPU mounting thing so I won't need the Evo. Which do you recommend?
i recommend the evo... not for the gpu thing. if you still dont want the evo then get the mini air
Edited by thrasher_565
https://linustechtips.com/topic/1434078-which-case/#findComment-15416230
