Hey guys, Building my first System and wanted suggestions and had a few questions.
Here is the PCPartPicker list : https://pcpartpicker.com/list/2JX9C6
I had some questions as well. I want to replace the front fan that comes with the 5000D with 3 LL120. I understand the 3 pack comes with a Lightning Node Pro so all those would go on there for RGB and for power on the pwm hub of the case. And the i150 AIO also has 3 ML fans that go on their own Commander Core for power and RGB. What would be the best fan slots to use for for the AIO and for the case PWM hub that will have the other 4 fans (3 front + rear).
Also is there any issues with the pwm hub having 2 different kind of fans? I understand the each hub should only have 1 kind of fans on it.
Has anyone used the 5000X case for a 12700K and 3080ti? I saw some video that the temps run high with the X case.
Lastly if there are any replacements you would make to the build with easy reasoning would be really appreciated! I will mostly use the PC for general gaming. Some FPS some MOBA
https://linustechtips.com/topic/1434007-first-build-suggestions-appretiated/
I would recommend this:https://pcpartpicker.com/user/Pcbuild12123/saved/#view=3n4PJx cause first of all, for your budget the mobo you chose is garbage I don’t like asus p series motherboards cause they have bad aesthetics and are low end even if they are x570 or z690, also I chose a ddr5 motherboard because your budget can support ddr5 and in a few years when you need to upgrade that will make it much, much easier. I also changes the case fans from ll120s to al120s from lian li cause they are so much easier to work with due to the daisy chaining so you can use 1 cable for 3 fans also please do not buy a windows 10 key for over a 100 bucks at sites like g2a (not a scam) you can get a windows 10 key for 25 dollars or less. After getting rid of the windows 10 key that opened up some breathing room to upgrade the other components so I changed the cpu to a 12900kf keeping the cost at about 2973 dollars and even after getting a windows key from g2a the cost will be still under 3k and it will get much better overclocking capabilities, better ram, about 10-20 more fps, and better aesthetics for about 75 more bucks than the list you made so I recommend using this.
