I have the 3060Ti Gaming X (dual fan).
I tried playing some non GPU intensive games like Overwatch and Hitman and the temps were literally going 40-50 and occasionally 60.
The performance was great but I’m confused how it can be that low. Even my 1660 used to be at 55-60c in Overwatch at all times.
I have a good case with big fans but I still think that’s pretty low.
What do you think?
https://linustechtips.com/topic/1433699-gpu-running-too-cold/
I think what @Carolineis saying, is that your games don't stress the new graphics card as much as they did the old one. So the games were pushing your old graphics card harder, therefore the old graphics card needed to run at higher percentages and temperatures.
If you have NVIDIA GeForce Experience, load up the performance overlay and see how much of your cpu & gpu are being used. It should show at least the gpu percentage and gpu temperature.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413459
I used it. My GPU was getting 60% utilization at the max.
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413460
That's why it's running cooler then. It's not pushing to 90-100% like your old gpu likely was. 40-60*C is fine. Your concern should be if it goes like 90 or higher. That's when I would take a step back, and maybe turn down some settings or get some better A/C in the room.
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413463
Yes my system has good cooling indeed but my home ambient temps suck rn cause I don’t have an AC yet and I recently moved. I’ll make sure to get an AC and probably a dehumidifier if that helps.
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413464
53 minutes ago, Victor Jones said:
But don’t those temps sound too low?
What FPS are you getting? is Vsync on limiting FPS?
If you run into either a CPU bottleneck in a not very graphic intense game or a fps limit via vsync or a FPS limit, the GPU will not even be trying. So when your 1660 may have been working really hard for say 250 FPS, a 3060 in the same game and same settings wouldn't even be trying.
GPU's right now do use more power then previously, but they use more power while getting much, much performance. At lower loads, they are actually much more efficient (same FPS, same settings, it will use less wattage to do it, and it likely has a better heatsink as well).
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413497
4 hours ago, Caroline said:
Your temps in terms of computing are ice cold. You don't need an AC and you should only worry when temps are over 90C tbh, anything lower is safe to run even during long periods of time, you *shouldn't* let parts run that hot but they won't die because of it.
I’m more concerned about humidity tbh. Not temps.
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413865
Run Furmark or Kombustor and report back.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
https://linustechtips.com/topic/1433699-gpu-running-too-cold/#findComment-15413897
