Using fan splitters as extension cables
Go to solution Solved by GuiltySpark_,
It will work.
Would it work to take a 4 pin fan splitter that has a female end and splits that into 2 male ends and simply use it as an extension cable with 2 male ends on each side by not connecting anything to the female end? Seems like it should work, but wanted to make sure.
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
      MSI MEG X870E Godlike
    • RAM
      G.Skill Trident Z5 Neo 24GBx2 DDR5-8000 CL40-48-48-128 1.40v (F5-8000J4048G24GX2-TZ5N)
    • GPU
      Aorus Xtreme Waterforce RTX 3090 TI
    • Case
      Corsair 7000D Airflow
    • Storage
      (All NVME SSDs) 1 X Samsung 990 Pro (4TB), 2 x 2TB WD Black sn850, Sabrent Rocket 4TB
    • PSU
      Corsair AX1600i, Fully Modular, 80+ Titanium
    • Display(s)
      Alienware AW3423DW, Alienware AW3225QF
    • Cooling
      Arctic Liquid Freezer ii 420, Built in 360mm gpu rad, 7 x 140mm Noctua NF-A14's (4 used as full case fan set, 3 used to upgrade cpu rad fans), 4 x 120mm Noctua NF-F12's (3 used to upgrade gpu rad stock fans, 1 used to fill last remaining case fan slot)
    • Keyboard
      Custom Keychron Q6 Pro
    • Mouse
      Asus Rog Spatha X
    • Sound
      Senheiser Momentum 4
    • Operating System
      Windows 11 Pro
https://linustechtips.com/topic/1433670-using-fan-splitters-as-extension-cables/
1 female to 2 male fan splitter? i dont think i've ever seen such a thing, normally it's the other way around
regardless, fan splitters normally only connect the RPM Sense from one side only, so you'll have to double confirm if it's what you want electrically
-sigh- feeling like I'm being too negative lately
That's the norm. Male header (pins) plug into female fan headers.
hmm... i guess i got it mixed up, the casing on the right made me think it's female but it's male, yea
