it is dusty? remove it and clean it as good as you can
bad air flow? remove your side panel and play some games..buy more case fans
turn the fan speeds up
if you just bought it, installed it and know you have enough air flow to keep cool... rma or attempt to apply new thermal paste to the core
https://linustechtips.com/topic/143345-overheating/#findComment-1913499
my gpu gets to 77C before it crashes
is that normal?
https://linustechtips.com/topic/143345-overheating/#findComment-1913515
And make sure your diver is up to date!  I accidentally installed 13.9 instead of 13.12 and had horrible stability issues (had an installer lying around after a reformat).
First Build:| Gigabyte 990FXa-UD3 | FX 8120 4.0Ghz | Coolermaster Seidon 240M | Asus Radeon HD 7870 | Kingston HyperX 3k 120GB SSD + WD Green 2TB HDD | Corsair RM750 | 8Gb Kingston HyperX 1866Mhz CL9| Fractal Define R4 White/Windowed |
https://linustechtips.com/topic/143345-overheating/#findComment-1913660
