I coded an application to create Active Directory Users and wanted to add a section that adds their Exchange mailbox. I keep getting the following error. I have tried doing some search on how to resolve it, none of the solution work so far.
Is there an alternate way to add a mailbox or is there a known solution to this issue, Please!
I am using the following code
 public Boolean CreateUserMailbox(string FirstName, string LastName, string Alias, string PassWord, string DomainName, string OrganizationalUnit)
            string Name = FirstName + " " + LastName;
            string PrincipalName = Alias + "@" + DomainName;
            Boolean success = false;
            RunspaceConfiguration rsConfig = RunspaceConfiguration.Create();
            SecureString spassword = new SecureString();
            spassword.Clear();
            foreach (char c in PassWord)
                spassword.AppendChar(c);
            PSSnapInException snapInException = null;
            PSSnapInInfo info = rsConfig.AddPSSnapIn("Microsoft.Exchange.Management.PowerShell.E2010", out snapInException);
            Runspace myRunSpace = RunspaceFactory.CreateRunspace();
            myRunSpace.Open();
            Pipeline pipeLine = myRunSpace.CreatePipeline();
            Command myCommand = new Command("New-MailBox");
            myCommand.Parameters.Add("Name", Name);
            myCommand.Parameters.Add("Alias", Alias);
            myCommand.Parameters.Add("UserPrincipalName", PrincipalName);
            myCommand.Parameters.Add("Confirm", false);
            myCommand.Parameters.Add("SamAccountName", Alias);
            myCommand.Parameters.Add("FirstName", FirstName);
            myCommand.Parameters.Add("LastName", LastName);
            myCommand.Parameters.Add("Password", spassword);
            myCommand.Parameters.Add("ResetPasswordOnNextLogon", false);
            myCommand.Parameters.Add("OrganizationalUnit", OrganizationalUnit);
            pipeLine.Commands.Add(myCommand);
            try
                pipeLine.Invoke();
            catch (Exception ex)
                MessageBox.Show(ex.Message);
            finally
                myRunSpace.Dispose();
                success = true;
            return success;
https://linustechtips.com/topic/1433286-creating-exchange-mailbox-c-help/
A quick Google suggests you get this error, because the machine you're running the application on does not have the Exchange 2010 Management Tools installed. Hence the Snap-In isn't available for PowerShell. Did you install the management tools?
Would help if you listed what you've already tried. Otherwise people are simply going to suggest the same things again.
As @Eigenvektorsaid that is one issue. If you still have a problem and if you are connected to that ^#$%^ office 365 in your domain then you need to wait for the new user to be pushed to the cloud service as well before assigning extra properties. I never found any methods exist to force push that from the API side but within Exchange UI itself you can do it manually.
