Hello all you wonderful people I am looking for some advice on where to go with my relatively new system. Here is my list of current parts that I'm considering upgrading:
AMD FX-6300 w/ Stock Cooler :(
EVGA GTX 760 4gb with ACX cooler
1tb HDD and 120gb SSD
21 inch 1080p Monitor
I mostly just play video games, but I'm interesting in things like video editing and 3d work... Amy recommendations? I'm not too heavily invested in productivity apps keep in mind. I definitely want to stick with Nvidia. But I feel like switching CPUs to Intel would just be a money pit. I have about $400 I'm looking to get rid of. Thanks guys.
https://linustechtips.com/topic/143250-where-should-i-upgrade-first/
Psu? Ram? Case? Mobo?
Heaven's Society - Like Anime? Check us Out Here!
Upgrade the cooler and/or the CPU, if you have limited RAM you will want to upgrade that if your video editing and if you think you need a new GPU you could get one of those
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
Cooler and then CPU to an 8320, if your board can handle it. RAM if you have less than 8GB.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I have 8gbs of Ram and a corsair 650 watt PSU. I dont think I need to upgrade any of those. If I upgrade to an 8350 and a good cooler will I notice much game improvements? Or should I jump on any cheap 780s I can find. I feel like that might bottleneck with my cpu though....I'm still fairly new at all this. Sorry for any confusion.
How are the temps?
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
I have 8gbs of Ram and a corsair 650 watt PSU. I dont think I need to upgrade any of those. If I upgrade to an 8350 and a good cooler will I notice much game improvements? Or should I jump on any cheap 780s I can find. I feel like that might bottleneck with my cpu though....I'm still fairly new at all this. Sorry for Amy confusion.
Be sure to quote the person that you are replying to in order for them to get a notification and reply to you
You should Quote someone when you reply to them.
First off, does your mobo support SLI and OC?
The FIRST thing you should do is figure that out, if it does then your fine.
You should then upgrade your stock cooler for 20-50$.
Then SLI your 760, if your psu can support the load.
From then on your next upgrade would be probably your PSU mobo and Cpu all at once
going to 700watts
intel haswell refresh or broadwell + z97 mobo.
I would get an 8350 that way you won't bottleneck *shudder* higher end gpus.
going to 700watts
Would SLI 760s be better than going straight to a higher end GPU? and thanks for the help so far.
Would SLI 760s be better than going straight to a 780 (non TI) and thanks for the help so far.
Well it depends how you view.
To me, I think the mobo is one of the most important things to have solidified, then the powersupply,
because that completely determines how good your PSU and GPU setup can be.
So if you have a mobo that supports OC and SLI
you've got a PSU that supports SLI and OC (wattage)
Then I'd opt for the 780, then SLI it later on.
I don't think you need to worry about the cpu bottlenecking, if i'm not mistaken it's like a i5 2006k (or something) from intel and it works fine for people
Well my Mobo is fine, that supports SLI, and my PSU is 650watt bronze Corsair PSU, so I believe I'd be OK with an SLI setup as well. Basically it boils down to a SLI, a better single GPU, a better AMD CPU, or jump ship and go intel. Biases aside I'm still looking for basically just better game performance now, while flexibility for future upgrades would just be a convenience.
Swap to 780 and a cpu cooler (25$)
