Does the MSI H510m-A-Pro power throttle the I5-11400f (Repost)
Solved by Guest,
It will only throttle if the VRMs get too hot. Since the 11400 is a 65w chip, you should have no problems as long as you have decent case air flow.
1
2
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
