need help for a guide/youtube video,, searched for a guide got the wrong laptop guides
Solved by LogicalDrm,
-> Moved to Laptops and Pre-Build Systems
For one, you are using incorrect search terms. Cleaning is rarely why laptops are opened. "disassembly" is the correct term. Here's iFixit guide
Usually you can go with similar model. The differences are minimal when it comes to body of the laptop.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals0 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
4
2
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
