Ive had my gaming rig for a while now and an issue started occurring where my whole computer would turn of instantly, motherboard and ram lights stay illuminated and the pc wont turn on again unless I flip it completely off from the wall and then back on. I think this may be an overheating issue but after checking with Hardware monitor I was not able to notice anything that went over 85 degrees under load.
Specs
5900x
Rtx 3070
32gb Ddr4
samsung m.2 1tb
850w corsair psu
https://linustechtips.com/topic/1429419-help/
Latest BIOS?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1429419-help/#findComment-15384491
Gonna need more detailed specs than that. What's your motherboard?
Due to my inability to think before I type, I frequently edit my posts. Please refresh before responding!
Tag me @drdrewnatic or quote me so I can see your response.
______________________________________________________________________________________________________________
CPU: INTEL CORE I5-12600K GPU: ASUS ROG STRIX GEFORCE RTX 2070 OC MB: GIGABYTE B660 AORUS MASTER DDR4 RAM: 2X8GB G.SKILL TRIDENT Z RGB 3200 CL16 BOOT: CRUCIAL P5 PLUS 1TB SSD: SAMSUNG 860 EVO 500GB HDD: SEAGATE 2TB 7200RPM PSU: EVGA G3 650W COOLER: THERMALRIGHT PEERLESS ASSASSIN 120 SE ARGO
01101100 01110100 01110100 01110011 01110100 01101111 01110010 01100101 00101110 01100011 01101111 01101101
https://linustechtips.com/topic/1429419-help/#findComment-15384504
1 hour ago, 191x7 said:
Latest BIOS?
Also my choice for likeliest possible culprit.  Might also do to refresh the OS.  One of those things that is cheap and easy, and might even help.  Not a strong chance, but it’s outside possible you’ve got a corrupted file somewhere.
https://linustechtips.com/topic/1429419-help/#findComment-15384535
19 minutes ago, QuetzalcoatL0202 said:
Im assuming it has something to do with the chipset under the onboardfan, its placed like directly inline with the gpu and I think its pretty much overlapping with a fat 3070.
Highly unlikely. The chipset doesn't actually get that hot, only when you're doing a ton of data transfer through it, so large file copies on NVMe drives connected through the chipset. It gets hot enough that it needs a fan during file transfers, but on most boards it actually doesn't need the chipset fan running. It is worth checking in something like HWiNFO64, but I doubt it's the culprit. Also don't use HWMonitor, it's been known to misreport temps on occasion.
22 minutes ago, QuetzalcoatL0202 said:
Motherboard is a x570 Asus Prime
Which one, they made like 3 different X570 boards called "Prime"? Prime-Pro? Prime-P? which one specifically?
https://linustechtips.com/topic/1429419-help/#findComment-15384551
3 minutes ago, QuetzalcoatL0202 said:
I got the place I bought it from to put on bios for 5000 series as its a pain to do if you don't already have and existing rig I heard, not sure if its been updated in a while
https://linustechtips.com/topic/1429419-help/#findComment-15384555
I don’t think it’s the problem, but if you really think the thing is being heated externally to the point it is causing problems (which I doubt) you could use a heat shield to test it. Aluminum foil makes a great heat shield. It’s also conductive of course, so an amount of care must be taken.  If you don’t have any you could buy a pack of chewing gum.  The silver side of the gum wrapper is aluminum foil and the paper side makes a decent non conductive surface (wood is not a good conductor of electricity) you can even use old wads of gum to stick the thing in place.  Chewing gum is also a lousy conductor.  If it DOES actually turn out to be the problem you can get a vaned heat sink for the chip.  If you happen to have one lying around that is also an option instead of the chewing gum.
https://linustechtips.com/topic/1429419-help/#findComment-15384582
2 hours ago, QuetzalcoatL0202 said:
Motherboard is a x570 Asus Prime, Im assuming it has something to do with the chipset under the onboardfan, its placed like directly inline with the gpu and I think its pretty much overlapping with a fat 3070.
Does this help?
There are two newer bioses for that board.
https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-X570-PRO/HelpDesk_BIOS/
I have a similar system (5900X + Prime X570-P + 32GB + RX 5700XT that covers the fan). Besides Asus having the fan curves of that chipset fan all wrong (annoyingly loud often), everything works, so the chipset fan probably isn't the cause of the issue.
Do you use Asus Armory Crate?
Do you use 1 piggy tail cable to power the GPU or two separate cables?
https://linustechtips.com/topic/1429419-help/#findComment-15384621
Im using two separate cables to power my gpu. Not using armory crate but should I?. It happens randomly, I could be playing ark in 1440p max settings or playing muck on all low settings and it would just randomly happen. I have an external fan blowing into my intake which seems to prevent it but its hard to tell.
https://linustechtips.com/topic/1429419-help/#findComment-15384643
That's good, always betetr to use separate cables if you can.
No, Armory crate is a known cause for issues.
Are you running HWMonitor as an administrator to see all the temperatures?
Windows updated?
Since you didn't have the latest bios, have you flashed the latest in the meantime?
Does the system crash during stability testing (CPU - Prime 95 Small FTT, GPU - Unigine Heaven looping)?
How high do the temps reach during stability testing?
https://linustechtips.com/topic/1429419-help/#findComment-15385220
I’m not a fan of armory crate, or really any extra unneeded junk. If it fixes the issue it isn’t unneeded junk though.
Re: update
it’s about rewriting the code not updating it.  Stuff gets corrupted sometimes. it’s why the refresh option exists.  I don’t know if update will rewrite  things like old registries or not.  If it only does it under some circumstances it’s got to be software.
Edited by Bombastinator
https://linustechtips.com/topic/1429419-help/#findComment-15385532
