truenas NIC problem
Go to solution Solved by breek,
I ended up removing the battery from my motherboard and it found it again.
so not sure what happened there
This is probably ignorance but i cannot for the life of me figure out what to do. So here we go:
I started tinkering with truenas. I had some old hardware laying around so i figured, why not.  I have it set up through a powerline adaptor to the attic. Created some pools with SMB share for my streaming pleasure. I noticed transfers weren't great. So i bought a new PCI-e 1Gb NIC and made me some brand spanking new CAT6 UTP cables.
At the start all was fine, truenas detects said NIC but since I'm a novice at best i try to figure out how multiple NIC's work and start just doing stuff, looking things up. Which ends up in my deleting of the NIC in the webinterface.
Since then, i cannot make it reappear. It just doesnt show up either on the server or http portal.
I've reset the whole thing to defaults, I've reseated it (using other slots and the same) and to verify it was still working, I put it in my desktop and in that it works fine. I've tried asking in the truenas discord but noone is answering, probably because either im dumb or it could be 1000 things.
https://linustechtips.com/topic/1429368-truenas-nic-problem/
FWIW, no amount of new NICs is going to fix this bottleneck. Powerline is horrible.
What is the rest of your hardware? (full list)
Are you using TrueNAS Core or Scale?
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15384094
Well for now I've had no real issues. It reached around 12MB/s peak. hoped it could do better since populating a server takes a while like that.
Truenas Core (free ofc, home use mainly to have some fun, centralize storage)
 Technical data
Compare in category
CPU series Intel® Core™ i7
Processor/type i7-4770
Processor generation 4th Gen (Haswell)
Processor cores (No.) 4 x
CPU speed 3.4 GHz
RAM
8 GB
Graphics card type Nvidia GeForce
Graphics card type GTX760
Graphics memory 1.5 GB
SSD size (total) 128 GB
SSD 1 type SSD
SSD 128 GB
SSD connection SSD SATA II (300 MB/s)
HDD capacity (total) 2048 GB
I upgraded the RAM tho to 16Gb
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15384103
 Technical data
Compare in category
CPU speed 3.4 GHz
RAM
8 GB
SSD 1 type SSD
SSD 128 GB
Well as mentioned Powerline is horrible. 12mb/s is pretty much 100mbit so I think your Powerline adapter or some other part in your network chain is limited to 100mbit.your PC's internal NIC will do 10x that no problemo.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15384151
I'm not all too familiar with TrueNAS but I am familiar with FreeBSD. I assume we're looking at the re0 interface? Check your /etc/rc.conf file and see if it has an entry for that interface. Should look something like this.
ifconfig_vtnet0="inet 192.168.0.238 netmask 255.255.255.0"
I don't know if TrueNAS reads from the /etc/rc.conf file though so it may be irrelevant.
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15384155
This is very much "YMMV", I've set up PL adaptors that do what they say on the tin, whilst having set up others on the same power strip that refuse to "pair" with each other, it's a proper shitshow, but good results are worth a week of work from a good sparkie running cat6 and lots of filler/paint.
Indeed, though it's most likely to be 2 or 3 "usual suspects", try to cut down on variables by moving the NAS around so it can benefit from direct connections etc. as Re0 reads as "onboard".
Making the assumption that something in /etc is suppressing the interface, a `grep -i "<new interface name (if you remember it)>" /etc -R` may find whatever is "blacklisting" it, or you may have to go deeper into device discovery software (FreeBSD gurus pls reply...).
Either way, with this type of OS there is nothing you can do that cannot be "undone", no matter how far "off piste" the answer is, persist my friend, persist!
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15384175
it appears as truenas doesn't. there's a couple rc.conf(....) in there but nothing really helpful in there.
thanks for the comment!
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15385298
I'm pretty sure it just defaulted the second one to "re1". The shell in truenas doesn't seem to want to do a grep though. or its taking insanely long
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15385305
for i'd just  like get it to work so I can confirm that, that's basically the reason why i bought it in the first place.
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15385309
Tonight or tomorrow I'll work on spinning up a TrueNAS Core VM. If we can replicate the problem perhaps we can figure out how to reverse it.
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15385466
any luck? I'm probably gonna return the NIC and try another. it's just not worth the hassle  🙂
thx anyway
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15389130
thx anyway
I'm not all that familiar with the TrueNAS UI. More of a CLI guy myself so unfortunately no. When you say you deleted it I take it you're not sure what you did? The NIC just kind of disappeared while you were tinkering?
I would assume if you powered off the system. Removed the NIC. Powered on the system. Powered off the system. Then re-installed it that it aught to recognize it as a new network device and add it back into the WebUI.
https://linustechtips.com/topic/1429368-truenas-nic-problem/#findComment-15389144
  • 1 month later...
