What are the temps on the CPU and GPU?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1429344-low-fps/#findComment-15383849
8 hours ago, Param said:
I have asus f570zd with 8gb ram and Nvidia gtx 1050 2500u ryzen 5 1tb hdd. I am getting continuously low fps like 20 to 30 in every game. Is there any solution for these?
lower settings.  that includes resolution.
this is an ok laptop,  problem is the screen is not adequate. its a 720p machine for the most part.
-Scott Manley, 2021
https://linustechtips.com/topic/1429344-low-fps/#findComment-15384352
  • 2 weeks later...
