Ethernet Surge Protectors with Ground Wires
Solved by brwainer,
Look closely at the screw in the center of your outlet covers. This screws into the metal housing of the socket, right? And the ground wire is connected to that housing as well, right? If not, you can replace the socket with one where the housing is grounded and therefore grounds the center screw. At that point you can just install the cable like this image on the right side:
Or, you can get a device like the left side, the keywords to search for are “ESD Ground Plug”, but those are almost always for a banana plug.
Source for the image: https://electronics.stackexchange.com/questions/442373/how-can-i-get-ground-from-a-nema-5-15r-wall-socket-without-electricity
