I need to save 20TB in duplicate.
Data will only be accessed like once a month for me to add the new files/changes.
I currently just have a few of those passport style Western Digital external drives it gets cumbersome going through all of them every time.
Any advice for a better solution? What should I get?
I decided against a RAID solution, because although the raid drives have parity, those systems have a 1-point failure regardless of the actual hard drives (in case the motherboard/cpu/software etc bricks the entire Synology etc device), and I don't want to in any way risk a loss of data.
https://linustechtips.com/topic/1427701-advice-cold-storage-solution/
Just use a linux based software raid, if something dies the array will be easily recoverable, you could even build a "recovery usb stick" that will run on anything capable of hosting the drives. If you do it right and build the OS on raid 1 (drives not used for storage) you should be able to literally pull them with the raid drives, shove them in a new case/machine and just boot it.
