Will RM750 fit into iCue 220T?
Go to solution Solved by ET_Explorer,
Yes! It should fit.
Hello there!
I'm purchasing parts for a new PC build and ran into a potential issue:
I have a Corsair iCue 220T case (mine specifically is the version with glass front panel, but to my knowledge everything else is the same as the Airflow) and am looking to get a Corsair RM750 PSU, but I've heard that this PSU is a non-standard size and might not fit unless I remove the 3.5" HDD trays?
I need to keep the 3.5" trays as I have HDDs that will go in those. I've also heard the RM750X might not have this size issue, but because the RM750 is on sale where I live, there's a pretty significant ($50) price difference. Because of this, I'd really like to know if I can safely pick up the RM750 while it's discounted.
List of my current plan for the build (220T Airflow was the only option), for reference (most components have already been purchased):
https://pcpartpicker.com/user/Lon3lyWanderer/saved/#view=jp66Q7
