Budget (including currency): max. 1400€ (1510,66 USD)
Country: Austria
Games, programs or workloads that it will be used for: mostly competitive shooters (currently Apex and R6) but also Games like ARK, Witcher 3 and Total War Warhammer.
Other details :
just need someone to tell me if I'm on the right path cause I get self conscious and overthink things when having to decide things on my own.
my part list so far: https://de.pcpartpicker.com/list/jbNv3y
https://linustechtips.com/topic/1425874-first-build/
Country: Austria
Other details :
I would spend a bit more for a 750W just for some wiggle room
edit: I would return both drives and get a single 1tb NVMe instead
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/1425874-first-build/#findComment-15359311
Country: Austria
Other details :
honestly looks fine to me not much to change up maybe get a better PSU like a 750W because you always want to go a bit above the recommended PSU for the GPU other than that looks good
https://linustechtips.com/topic/1425874-first-build/#findComment-15359317
Get a 1440p monitor, it'll only cost a little more and trhose games will run at a great framerate no problem with a 3060ti at 1440p.  27 inches is pushing it for 1080p, text is gonna look kinda shitty IMO.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1425874-first-build/#findComment-15359347
