Hi all,
Forgive me if this question has been asked a million times already but I'm wondering what would be a suitable replacement for my EVGA GTX 1080 Ti SC2?
I tend to mainly play games with the card and do the occasional hash cracking but nothing too over the top. It's currently running my Alienware AW3418DW.
Any help or advice would be greatly appreciated.
Phizix
| Corsair 750D Airflow Edition | Intel I7 8700K | Gigabyte Aorus Gaming 7 | CMK32GX4M2B3000C15
| EVGA GTX 1080 Ti SC2 | 750w Seasonic Focus Gold | NZXT Kraken X62
| 980 Pro 1TB M.2 | 970 Evo 250GB M.2 | 860 QVO 1TB SSD | 850 Evo 500GB SSD | Synology DS920+
| Alienware AW3418DW | Creative Soundblaster Z | Creative Katana | Sennheiser HD 6XX
| Logitech MX Master 3 | Roccat Vulcan Aimo | Official Microsoft Xbox Controller
| Xbox Series X | Xbox One | PS4 Pro
https://linustechtips.com/topic/1425788-1080ti-suitable-replacement/
6 minutes ago, Phizix said:
Hi all,
Phizix
I mean really nothing less than a 3080 will be that huge of an upgrade.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
So a 1080ti is similar to a 3060\3060ti, if you are looking to upgrade as you need more FPS or want ray tracing you are probably going to want to go with a 3080 or higher at the least, otherwise it is probably not worth upgrading at all as the 1080ti is still a very capable GPU.
I would suggest you wait if you can as new cards this year are expected from AMD, Nvidia and even Intel.  Which means if you upgrade now, in 6 months there will be another generation out.
This.
I'm also rocking a 1080Ti and, at this point, I just don't think it's worthwhile buying anything.
I'd rather wait until later this year when both AMD and nVidia are expected to announce and launch their new series of cards.
Thank you everyone!
I think from the above advice I'll wait until later in the year and see what Nvidia brings out!
Thanks again!
35 minutes ago, Phizix said:
Hi all,
Phizix
I did replace my EVGA 1080 ti SC2.
This is the difference in two games.
i7 8086k(Intel 6 core)
Shadow of the Tomb Raider Highest preset.
        1080p     1440p            4k
EVGA SC2 1080 ti                                    123fps        84fps      ----- Below 60fps
EVGA FTW3 Ultra 2080 ti                        148fps      119fps       65fps  =< 3070 ti
EVGA FTW3 Ultra 3080 ti                        156fps      147fps       95fps
Assassins Creed Odyssey on Ultra high
        1080p     1440p            4k
EVGA SC2 1080 ti                                    77fps        65fps      ----- Below 60fps
EVGA FTW3 Ultra 2080 ti                        92fps        80fps        54fps  =< 3070 ti
EVGA FTW3 Ultra 3080 ti                      105fps        94fps        66fps
My i7 8086k was at 5ghz all cores.
Compared to my 5800x and i9 10900k performance tanked on the i7 with the 3080 ti.
I would go with a 3070 ti or 3080 if you plan on keeping the i7 8700k for a while.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
