Case front I/O not working as intended
FRD
Back in 2020 I made a similar topic about my case front I/O not working properly.
For the family PC we use a simple and pretty cheap Aerocool case. Bought brand new in 2020. The front has 2x USB 3.0, an SD/microSD card reader and headphone/mic inputs. The sound inputs work totally fine.
The USB 3.0 ports work, but badly. They're connected directly to the Asus' motherboard USB 3.0 header. When using 2x USB flash drives together on the front, I'm not able to transfer big files, as it will cut off the transfer.
Also, when 1 USB flash drive is connected on the front and transferring big or many files to let's say an external HDD that's connected on the back, often it will stop the transfer because the USB flash drive is suddenly not detected anymore.
Randomly it will disconnect itself. Also, the transfer speed is slow, like 10 or 20 mb/s, while USB 3.0 can easily do 100+ on the back USB 3.0 ports.
As for the card reader. It's not shown in the computer's drives, but when you put in an SD card, it will show up. It supports up to 64GB cards. However, more than half of the time it won't do anything. I put in a card and nothing will show up at all. Lately I just used a 8GB card, which isn't superfast, but it didn't work.
Note that I never use the front USB and card reader together. I'm only confident to transfer small files quickly with the front I/O ports used together.
Anybody that can help? How to fix this?
I can't RMA the case anymore and buying a new case is the only possibility.
The motherboard is fine, the connectors seem to be doing what they need to.
Chipset drivers, USB drivers and enough power on the front panel connectors, that is essential.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
When I built the PC I'm certain I installed all chipset and USB drivers. I could update them maybe, if I look on the motherboard's site.
How do I assure that the front panel gets enough power? I'm using a 450W PSU with a Ryzen 3400G if that matters.
Did this happen on a B450 motherboard? When transferring large files a couple of my flash drives seemed to have been permanently corrupted from the USB drive no longer being found/recognized in the middle of copying large files. I had happen on a ASRock and Asus B450 motherboards I have.
Yes! That's right. It's a Asus Prime B450M-A.
I actually recall right now somehow reading about such a thing back in 2020. That's the exact thing that's happening, just the USB drives won't get corrupted, just not recognized during copying. Do you know the fix, how?
Your Power supply is kinda tiny... try 850 Watts at least from companies like Seasonic or Corsair... Gold 80+ rating
You shold have less problems powering hardware and devices...
Intel Core i9 10920x CPU; ASUS ROG Strix x299-E Gaming II Motherboard; 64 GB Corsair Vengeance LPX DDR4 2666 MHz Quad Channel Kit; EVGA RTX 2070 Gaming 8 GB; 2 TB Samsung 970 EVO Plus NVMe m.2 SSD & 1 TB Samsung 970 EVO Plus NVMe m.2 SSD; 1 TB WD Blue SATA SSD; 2x 6 TB HGST DeskStar NAS Hard Drives; Corsair Hydro H150i RGB PRO XT All In One Cooler; Corsair RM1000i 1000 Watt PSU; Corsair Commander Pro Lighting & Fan control; 4x Corsair HD120 RGB 120 mm fans - Intake ; Lian Li 011-Dynamic Razer Edition cube case, Windows 11 Pro 23H2
I hope you're joking. 450W is plenty for an iGPU system. I have no actual GPU installed and a better 80 Plus rating only helps with efficiency, not performance. It's not that my system has no room left to power things. My system draws only about 150-200W, so I could get away with even a cheaper PSU, but I don't want a bad quality one. The one I use is a Corsair by the way.
This is utterly wrong and useless "advice."
450W is more than enough for any system without a discrete GPU.
Buying PSU's based on brand is a terrible idea.
80+ is not an indicator of quality.
Not trying to be mean here but basically your post is incorrect on every level and I feel and obligation to push back when I see stuff like this because while @FRDis knowledgeable enough to reject it as the rubbish it is, it still might mislead some newbie who stumbles upon this thread at a later date.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Thanks for clarifying. I can't blame him too much, since he's new here, but also his advice is not really well thought of.
It's almost like some of those people who say you need a 750W overkill PSU for a RTX 3050 system, just an example. Brand and rating indeed are not the only thing. It's better to refer to the PSU tier list on this forum if you don't know and need a good indication of what's good and not.
I remember it was in the tech news for a while last year, X570 / B550 / B450 motherboards had some kind of USB drop-out issue.
That was eventually patched...via AGESA (BIOS) update.
https://www.tomshardware.com/news/amd-suggest-possible-fixes-for-usb-connectivity-issues
Quote
The issues seem confined to Ryzen 3000 and 5000 series CPUs in 500- and 400-series motherboards (i.e., X570, X470, B550, and B450) and consist of random dropouts for USB-connected devices. The complaints encompass several different types of USB devices, including unresponsive external capture devices, momentary keyboard connection drops, slow mouse responses, issues with VR headsets, external storage devices, and USB-connected CPU coolers.
BIOS updates started rolling out in April / May of last year.
Check the current version of BIOS you have flashed onto your motherboard.
If it is older than...say April 2021, update it.
Looking at the ASUS PRIME B450M-A BIOS list, it LOOKS like BIOS version 3202 (2021/06/24) contained the fix.
The USB issue was resolved with...supposedly ASESA v1.2.0.2 (and later).
BIOS version 3002 mentioned AGESA v1.2.0.1, while version 3202 mentioned AGESA v1.2.0.3.
https://www.reddit.com/r/Amd/comments/m2wqkf/updated_agesa_coming_for_intermittent_usb/
Quote
We would like to thank the community here on r/AMD for its assistance with logs and reports as we investigated the intermittent USB connectivity you highlighted. With your help, we believe we have isolated the root cause and developed a solution that addresses a range of reported symptoms, including (but not limited to): USB port dropout, USB 2.0 audio crackling (e.g. DAC/AMP combos), and USB/PCIe Gen 4 exclusion.
AMD has prepared AGESA 1.2.0.2 to deploy this update, and we plan to distribute 1.2.0.2 to our motherboard partners for integration in about a week. Customers can expect downloadable BIOSes containing AGESA 1.2.0.2 to begin with beta updates in early April. The exact update schedule for your system will depend on the test and implementation schedule for your vendor and specific motherboard model. If you continue to experience intermittent USB connectivity issues after updating your system to AGESA 1.2.0.2, we encourage you to download the standalone AMD Bug Report Tool and open a ticket with AMD Customer Support.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Pardon, I made the assumption the OP was running a discrete graphics card with his setup. I should have read more carefully. I stand corrected on the issue at hand. I had USB gremlins with my last motherboard. ... I feel the misery
Again it was an off the cuff statement that maybe the motherboard was not getting enough juice... but, as I said, I stand corrected.
My old, recently dead pc (I think the mobo bit the dust since I get the same weird graphical artifacts/freezes regardless of if I turn of on-board graphics, and have the videocard in, or take it out and use on-board graphics, plus mashing delete/f12 doesn't do jack when rebooting) had a similar issue long before it died.
Basically I could plug my mouse or headphone charging cable into the front usb sockets, and they would work. But anything else, including usb2.0 thumb drives, just wouldn't show or light up or anything. actually gamepads wouldn't 'talk' to the pc either.
It's okay. Just with a weaker graphics card 450W would still be fine, but it's usually better to have more watts. I never ran into a PC yet that doesn't get enough power or is at the limit.
I can imagine how annoying it would be if components would not get enough power. In my case I feel like the case was bad from factory, but it's a motherboard issue after all. I still need to try the fix.
That's a similar, yet more serious problem. Unfortunately it died. You did not try to replace the PSU or maybe case or you left it as it was? Sometimes it can also be something else that's unclear what it would be. Even the case could have bad ports itself. It could even be something simple as a power saving mode too.
