Final Parts list
Go to solution Solved by Morris_lee_9116,
4 minutes ago, 191x7 said:
Seems ok.
Would the i5 12400F and an MSI B660 board be a lot pricier? If not, it's a way better option.
I checked PCpartpicker the CPU is about the same but the board is about 50% more
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£162.99 @ AWD-IT)
Motherboard: Gigabyte B660M DS3H DDR4 Micro ATX LGA1700 Motherboard  (£99.14 @ Technextday)
Total: £262.13
Generated by PCPartPicker 2022-04-19 11:05 BST+0100
still I'd say it's worth it to go 12400F
@Overpowered66please consider going 12th gen
also cryorig M9 isn't that great so you can go 12th gen if you just use the stock cooler comes with the 12400F
Budget (including currency): £580
Country: England
Games, programs or workloads that it will be used for: Minecraft, Fortnite, Apex Legends, Warface, Roblox, Blender, Photoshop
I am going to be ordering parts soon, so wanted to get some feedback on the decided parts list for 1080p gaming:
- i5 11600K (£160 from local retailer)
- MSI B560M-A PRO (£67)
- Cryorig M9 Plus air cooler (£26)
- Crucial Ballistix 16gb DDR4-3200 CL16 (£57)
- Samsung 970 Evo Plus 250GB M.2 (£25)
- WD BLUE 500GB HDD (£0, from old pc)
- GTX 1080 (auction, but want to keep price under £140)
- Seasonic Core GC 650W 80+ Gold PSU (£53)
- DEEPCOOL MATREXX 40 3f (£35)
- Win10 Pro (£11)
Total- £572 (including delivery price)
https://linustechtips.com/topic/1425739-final-parts-list/
Seems ok.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358276
Seems ok.
Total: £262.13
"Freedom is the right of all sentient beings"
If my comment helped you please mark it as solution. Refresh before you reply, I edit comments often.
Current PC Spec
CPU: AMD Ryzen 5 3600
CPU Cooler: Scythe Mugen 5
Motherboard: MSI B550 Tomahawk
RAM: XPG D10 White 2x8GB 3200 CL16
GPU: EVGA RTX 3060 Ti XC
Storages: 1x512GB Intel 760P M.2 NVME(boot drive)
1x2TB Umax M1500 Gen4 M.2 NVME(Game storage)
1x1TB Adata SU800 Ultiamte 2.5 inch Sata3 SSD(Game storage)
1x3TB Toshiba 7200RPM CMR drive
Case: Lian Li Lancool II Mesh
PSU: Seasonic Focus GX-850
Keyboard: Ducky Zero 3108 Cherry MX red
Mouse: Logitech G603 LightSpeed
Headphone: Audio-Technica ATH-M20x
Microphone: AVerMedia AM310
Flight stick: Thrustmaster T16000M FCS 3 pack
My Steam Profile (from SteamDB)
  • Value: $308
  • Games owned: 229
  • Games played: 163 (71%)
  • Hours on record: 4,976.9h
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358280
Go 12th gen or ryzen 5000 (12th gen is futureproof but ryzen 5000 has better boards for the same price)
M9 is trash 92mm so just ditch that and get a cheap 120mm tower like gammax 400/v2/gte, vetroo v5, etc.
Core gc is a lowend model so consider a diff gold psu in the 600w range since any less than 750w is what id consider a throwaway psu that youll upgrade when you swap parts so might aswell get better efficiency
Otherwise looks great actually, everything looks to be well specced and nothing overpriced
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358295
like i said I'd just ditch the M9 and go 12th gen with 12400F and stock cooler, since you can always upgrade from stock cooler easily but good luck trying to sell that Cryorig M9
Current PC Spec
  • Value: $308
  • Games owned: 229
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358300
Total: £262.13
34 minutes ago, 191x7 said:
Seems ok.
Thanks for your feedback, here is an updated parts list:
-i5 12400f
-Gigabyte B660M DS3H DDR4
-Crucial Ballistix 16GB DDR4-3200 CL16
-Samsung 970 Evo Plus 250GB M.2
-WD BLUE 500GB HDD (from old pc)
-GTX 1080 (auction)
-Seasonic Core GC 650W (cannot fit better PSU in budget)
-DEEPCOOL MATREXX 40 3f
-Win10 Pro
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358325
-i5 12400f
-GTX 1080 (auction)
-Win10 Pro
my dumbass is about to ask: "why do you have a 500GB hard drive in 2022" then i saw it's from old PC
this looks good, enjoy your new PC
Current PC Spec
  • Value: $308
  • Games owned: 229
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358328
5 minutes ago, Morris_lee_9116 said:
my retarded brain is about to ask: "why do you have a 500GB hard drive in 2022" then i saw it's from old PC
Lol I had a HP Prodesk 600 G1 SFF, hard drive is from that. And, thanks for your help!
https://linustechtips.com/topic/1425739-final-parts-list/#findComment-15358334
