ram Which module should i do 2x8 3600 or 4x8 3000 for R5 4650g ?
Solved by berberries,
Seeing you are using an iGPU you would really benefit from a ram speed increase from 3000Mhz to 3600MHz, go with the 2x8GB 3600MHz kit
Featured Topics
ItsHunterM8 ·
Posted in Troubleshooting0 -
1
3
2
2
Worstcaster ·
Posted in Peripherals2 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
