Where should I put my case fan?
da na
Retro build, old case with barely any airflow, you know the drill.
Could either put a 60mm case fan on the front or rear. Which would be best? Rear is right behind the CPU heatsink fan so I think it's less necessary there since all it's doing is blowing a little extra CPU heat out. In the front it's bringing air in. I do have a blower GPU though and those are good for negative pressure right?
(What I'm cooling is a HD 5870 and Q9550. About 300w total)
Which do you recommend?
I'd start with the front, but it should be easy enough to set it up on the front for a couple days then move to the rear to see temperature difference yeah?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
I remember a thread awhile back that someone had stuffed some hardware into a case that wasn't really designed for it or something -- had a front grille pattern of holes in the skeleton that they wished to open the case to in order to better ventilate. I suggested copying that grille pattern to a piece of paper or cardboard, then transferring that pattern to the case  and drilling the holes slowly, letting the bit heat up and help to melt its way through.
That being said, heat does rise, so perhaps do something similar in the top of the case with a couple fans hung beneath?
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Is putting a fan in both spots not an option?
For good airflow with a blower GPU, I'd (personally) want the the case to have equal intake and exhaust. The GPU counts as an exhaust, so an intake would be preferred if that's the only option. Not knowing what the rest of the system looks like is hard though. If the PSU is also acting as a rear top exhaust (common in old cases), then more intake is a top priority.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Unfortunately can't do both. Not willing to spend on a fan splitter for this build that won't be frequently used or pushed to its limits and I'm out of headers. Yes, PSU on top.
