what hdr mode should i pick
Solved by iajadsfa,
3 minutes ago, Cerberrus27 said:Gameing not really playing anything crazy right now mostly. League of legends valorant stuff like that.
seems like valorant does have HDR, however, its up to you to decide if the downsides are worth it. SDR will look worse and performance may suffer. Auto HDR is worth a try if you really want it but start by making sure that you are already getting as much as you can in sdr. Nvidia control panel can sometimes set your color depth to lower than your monitor supports. Check those first since they can make a much bigger difference than any HDR
