which version of cinebench?
57 minutes ago, gamagama69 said:
I can't really get any faster with a b350 board
i oc my ram to 3600 no issue, and im pretty sure it would go higher if i tried.
Is this normal for having 3200mhz ram?
ram speed is mostly irrelevant for this test, going from 3200 to 3600 gives like 100-150 points more…
generally RAM speeds are far less important than people think.
fairly high temp limits
and this *is* 100% irrelevant, the only thing Ryzen boost cares about is temps, the lower temps are the higher it clocks…  having a high "temp limit" does nothing because  you want *low* temps at all times.
-Scott Manley, 2021
49 minutes ago, gamagama69 said:
I just realized my performance was low. I should be getting at least 1000 points higher. Is this normal for having 3200mhz ram? I can't really get any faster with a b350 board. I have pbo with fairly high temp limits and docp enabled but no manual oc.
Did you have anything else running on the system while doing the run?
Also may be hitting a VRM bottleneck on a b350 board. Im having this issue with my x470 board with 3900x my vrm is good for 100Amp max usually see about 95 real world and my chip wanting more power vrm just cannot give it.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
10 minutes ago, ddennis002 said:
VRM bottleneck
possible. i always forget about that since the vrms on my b350m are pretty good… no thottling, ~70c max (cpu) and pulls like 90w which is i think quite high for a 3600 with negative voltage offset.
-Scott Manley, 2021
No. I'm just surprised it would have issues running at 110ish watts, since it has some cooling. I chekc the vrms and the temps are in the mid 60s
I should've listed my board I have a strix b350 f gaming
