RGB Fans
11 hours ago, YGFJoao said:I'm willing to spend up to $200 (although I'd like it to be under that) and plan on using 3 fans as exhaust fans for my AIO on top of the case and 3 for intake on the front. The build I'm going for is all black with the RGB to brighten it up a bit.
Which AIO are you getting?
To try to stay under budget and give you the best band for your buck. Look at these.
3 pack comes with the lighting node core, so the RGB would plug into the 6 port controller and you plug that into sata power and usb header on the mobo and can control the RGB from corsair iCue. PWM for the fan would be from your Motherboard.
https://www.newegg.com/corsair-co-9050094-ww-case-fan/p/N82E16835181182
If you want Fan control and RGB control in the same place you can opt for a Corsair Commander Core XT to replace the included Lighting Node Core with the fans.
The Commander Core XT will give you 6 RGB and 6 Fan headers and allow you to route all the cables to one area and control both fan profile and rgb from the iCue software.
iCue also has alot of built-in add ons that will control Motherboard RGB and any RGB connected to 12v or 5v Addressable RGB as well.
I love iCue all my RGB is Corsair and controlled in the iCue software. Mouse, keyboard, waterblock, fans, mouse pad, rgb light strips. My next upgrade is to go for one of Corsair iCue PSU and Corsair Hydro X Pump/Res Combo. All of which can be controlled though iCue.
