I recently watched Linus talk about the sff Dell Optiplex computers and upgrading the video card with a zotec gtx 1650 low profile card. And I’ve seen others on you tube say that since this is a 75 watt gpu that it could damage my system. The only card that’s recommended is the msi gt 1030 low profile gpu. I trust Linus but I need to know if the 1650 card would actually damage my system?
Dell Optiplex 7020 sff
I5 4th gen processor
16gb DDR 3 1600
120gb solid state drive
2tb sata hard drive
https://linustechtips.com/topic/1421068-graphic-card-help-needed/
How many watts is the PSU?
A gpu shouldn't 'damage' a system but if the power supply isn't sufficient it will shut down. (assuming the power supply isn't a fire hazard in itself, most in prebuilds are not)
Who says a gpu would damage your system (Drop a link to the video that says this)
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
It's not going to "damage" your system. Either the 255W power supply will have enough power to run the system with the GPU installed, or it won't.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
According to the Dell spec sheet for the Optiplex 7020, the SFF variant includes a 255W PSU.
If the i5 is the 4440, 4460, etc, and not a K variant, which is likely, then it should be fine. Those chips don't draw much power. Even if it is a 4690K, it's potentially fine, because you're not going to be able to overclock it anyway.
I have the 255 watt psu in my system
