Pc won’t post
Solved by RAM555789,
Do any fans come on for the CPU, GPU or case? If there not turning on it sounds like your motherboard is not hooked up to your case power button properly. I'll attach a picture from the manual that points the the power reset button where your headers should connect around for. If you wanna see the manual yourself I'll also link it, pg.19 on goes over connectors. mb_manual_z690-gaming-x-series_e.pdf (gigabyte.com)
