Hey guys!
Last November, I assembled a budget build as follows:
  • Mobo: ASUS PRIME B450M-GAMING/BR
  • APU: Ryzen 5 5600g
  • RAM: 2 x Corsair Vengeance LPX 8GB 3000Mhz DDR4 C16 Black
  • Power: Corsair CV650, 650W, 80 Plus Bronze
  • SO: Win11 Home 64bit
It all went well for 3 months. In Feb/2022, while playing some MasterDuel, the screen went black. The display kept showing "no input" errors from the HDMI, so I tested with other monitors and cables but still had the "no input" thing.
When connecting the display to the mobo via VGA it worked, but only in low resolution and showing red bars all over the screen (see image) even in the BIOS. Reinstalling the drivers and updating the BIOS did not solve the problems.
Thinking it was something with the mobo output, I got a replacement from the store, but the problem persisted with the new one. After this, I tried connecting an old GPU to it, with which it worked as it should.
Since the MEMTEST found no errors with the RAM, I guess the APU has some hardware problem, right? Any takes on this?
Thanks for the help and sorry for my english. 🙂
https://linustechtips.com/topic/1420077-no-display-with-risen-5600g/
17 minutes ago, josearmandovd said:
Hey guys!
sounds more like a mobo issue try not usiing a porrt on the bord use a hub connected to front io same thing happened to my 5700g and my 3400g
They tried another mobo already.
Yeah, would suspect the APU too.
F@H
GPD Win 2
34 minutes ago, josearmandovd said:
Hey guys!
You said it works with a GPU and issue did not go away with a new MB. You have a faulty APU/iGPU on your CPU.
You can take a peek or reseat it but I would start an RMA
I would check the pins on the CPU and maybe try in a different motherboard model, but it is likely that the integrated GPU of the APU (CPU) is faulty.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
