so my gpu usage is very low in games and i cant figer out if its a software side issue or hardware side(i do have a felling its my ram thats the hardware bottle neck) can anyone help?
CPU - Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
RAM - 2x2(4GB) DDR3 one stick is on around 600mhz and the other is at around 800 mhz
GPU - GT710 2GB DDR3 and 8GB/s GPU memory bandwidth
heres a screen shot of gpuz saying the cap reason is idle and idk if its a software side issue
https://linustechtips.com/topic/1418890-gpu-usage-low/
Have you tried running that (whatever it is) in full screen?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310113
3 minutes ago, bmx6454 said:
based on your other post, it sounds like it's a cpu bottleneck.
hm well i was thinking the same but not untill i saw used another set up with a pentium runing at 3.3GHz and gt 730 with 8 gb ram and there was no bottle necks there so i went on asumeing it was my ram
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310115
it could be your ram, what is the ram usage in game? and if your cpu is at 100% in game, the cpu is bottlenecking as well. no offense, but it a pretty old low end build, this is to be expected.
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310121
yea the cpu is kinda acting wierd so i asume its being bttle necked by the cpu and the cpu also dosnt wanna go to 100% so im just confused with this system
and dw i dont get offended lol
im not a twitter user(meme)
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310132
based on your other thread, it sounds like it is going to 100%, task manager is a bad indicator of usage, i would trust afterburner more.
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310135
4 minutes ago, Sambadtech said:
ok well do u think the gpu bottle neck is ram or cpu or maybe even both
It's hard to believe anything would bottleneck a GT 710. But it might be the CPU in your case.
I'd recommend changing everything. Pretty much anything new is a lot better than the stuff you already have.
To be blunt, pretty much anything newer than 10 years is better.
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310142
im saving up with my lunch money for new ram (16GB) and after the ram i was gonna get new cpu with mother board because the socket thing
i was planing on the i5 4th gen with any motherboard that supports it
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310146
do not purchase new pc parts with no way of actually testing/deploying them as you will not be able to determine if the parts are functional before their return period has expired
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310150
is there a way i can test what parts are good with what?like a website that when i select parts for a full pc and it will tell if it has some flaws? like a build test
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310153
you need to test the parts you receive in the mail. a website isnt going to test the physical parts and compatibility has nothing to do with functionality testing
https://linustechtips.com/topic/1418890-gpu-usage-low/#findComment-15310155
