MOS Blackpack cleaning
Solved by manikyath,
something i've done in the past to get smell out of a backpack was to just douse it in deodorant... but ofcourse watch out with the stuff like "axe dry" and deodorants like that, they contain a whole lot of stuff that wont evaporate well.
past that, just a soapy sponge and elbow grease can do wonderss already.
as for stuff to avoid.. i generally tend to "progressively increase" in the products i use, starting with very soft "things you use on your body" level of products, and get more intense as the previous thing didnt work. if you go straight for something that damages the material you cant go back, but if something less didnt help it's either stained backpack or faded color from an intense cleaning product.
