Silent Fan Controller
Go to solution Solved by Theo,
Scythe Kaze Master 2?
Hiya guys, I'm pretty obsessed with having a proper silent PC, Its already really quiet but its still too much haha so could anyone recommend a fan controller which allows you to completely switch off the fans as I already run my fans at minimum RPM's but i'd like to be able to switch them completely off when I'm not doing anything demanding. So far I've come across this http://www.amazon.co.uk/NesteQ-FanMax-Control-Unit-Black/dp/B002B7LD60 but it's out of stock everywhere (I think its discontinued). It needs to support at least 6 fans and I don't really want to spend more than £30 ($50 US). Also I'm in england. cheers guys.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/141780-silent-fan-controller/
I think all fan controllers should be able to completely switch them off if I'm not mistaken. Would have to look at the range of voltages it allows or something.
Most are 5-12 volts.
@loccilucas I'm currently running a "g vans tactus 6"
Loving it to death, it works really nice and the features actually work properly lol
It's touch screen, has 0 volts, to 12 volt control, lots of different colors for the LCD, temperature sensors and has automatic fan control you can use as well.
It's really nice for the price (60-80 USD)
( i know its out of budget, but its extremely nice for what it does)
Lamptron, G vans and phobya all make a version.  Here's the link to the lamptron version: http://www.overclockers.co.uk/showproduct.php?prodid=BB-004-LP
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892812
Thanks that looks good, it is alittle pricy though, £50 is pretty expensive, ill have alook and see if I can find it cheaper
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892857
nzxt sentry mesh
It's says on NZXT's website that the minimum fan speed is 40%
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892872
Looks alright but you can't turn the fans completely off :/
http://www.overclockers.com/scythe-kaze-master-ii
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892907
Yeah you can, i have one
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892930
Oh but it says the minimum output is 3.7V?
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892948
http://www.scan.co.uk/products/akasa-525-fc-six-fan-control-for-6-fans-down-to-zero-rpm-20w-per-channel-brushed-ali-panel Just come across this, It seems to be everything i'm looking for, how is the quality of akasa products though?
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1892981
for fans to be spinning, but you can turn them off
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1893020
Oh right cheers, I'll have a look into it, thanks for the help guys.
https://linustechtips.com/topic/141780-silent-fan-controller/#findComment-1893035
