Arc Mini R2 rattle problem
My HDD makes my case rattle.
Help me please.
Does the sound stop when you press or remove the side panel?
CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback
Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TB
PSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623
No, it only rattles when i install something, copying files, ect.
And can you feel the case vibrate, or is the sound coming from the hdd?
