Hi,
I have a fairly recent LG TV with nothing physically plugged in (except power of course!). I only use it to stream content over wifi. The problem is that because the TV has no inputs connected, it often defaults to Cable-in, which is just LOUD white noise.
I was wondering if I could use some kind of HDMI dummy to fake an input so that the TV defaults to that instead of Cable. I know this is not the intended use case for HDMI dummies (unlocking remote desktop, mining stuff, etc.).
Has anyone tried to use one of those as a display input? Or any better suggestion?
Thanks!
https://linustechtips.com/topic/1416111-using-hdmi-dummy-as-an-input/
Those dongles simulate a display, so connecting a display to a display is unlikely to do anything good. You'd need a source. Not sure what else is out there.
