Combatible Glasfiber Module for Zyxel Switch?
Required
Hi
Long storry Short our Homenetwork is weird I know but I want to make them as normal as Possible.
So I got another ZYXEL GS2220-10 EU region 8-port Switch who hopefully will work as I intend.
Thats not the Topic for today its about a compatible Glasfiber Adapter with the Active Link what every Transfer Info.
Is there a 3rd Party one? Sadly I found for many Company an but not for Zyxel...
Thanks
From AT. :x
Chances are, if ZYXEL doesn't have a whitelist of "approved" SFPs, just about any ones you find will probably work.
Gigabit SFPs are very cheap because they have been obsolete for a very long time, so you should be able to find some for not much more than the cost of postage.
