Which slot to use for a M.2 PCI-E adapter?
this is where the motherboard manual is actually helpful:
https://download.asrock.com/Manual/X370 Taichi.pdf
page 25 has some details about which slot conflixts with what:
QuotePCIe slots:
PCIE1 (PCIe 2.0 x1 slot) is used for PCI Express x1 lane width cards.
PCIE2 (PCIe 3.0 x16 slot) is used for PCI Express x16 lane width graphics cards.
PCIE3 (PCIe 3.0 x16 slot) is used for PCI Express x8 lane width graphics cards.
PCIE4 (PCIe 2.0 x1 slot) is used for PCI Express x1 lane width cards.
PCIE5 (PCIe 2.0 x16 slot) is used for PCI Express x4 lane width graphics cards.
* If PCIE5 slot is occupied, M2_2 will be disabled
slot 5 (the very bottom one) is shared with the bottom M.2 slot, so that one is out already.
it also mentions that slot 2 and 3 (the GPU one and the other big one) are sharing 16 CPU lanes, so if you use slot 3 you're cutting GPU lanes in half.
so i suppose this means either of the 1x slots. i dont directly find a note that either one of these are shared with anything else, so i suppose both are fair game.
